TFT Display neues Aussehen verleihen
  • Hallo !
    Habe mit den Hexeditor von ECM das Byte 65 einfach von 00 auf 20 geändert und somit ein neues Aussehen bekommen.
    Beim Sondermodell Fiat 500 Riva hat das TFT Display ein eigenes Aussehen währe neugierig welcher Codezahl der beim Byte 65 eingetragen hat?
    Gruss Stone855 :)
    Mein 500C: Ein 1.2 Liter mit Schaltgetriebe und TFT Tacho und roten Stoffdach
  • Hallo LaFee!
    Es gibt verschiedene TFT Display.
    Meiner ist in der Standarteinstellung Byte 65 auf 00 eingestellt,kann aber auch auf 20 eingestellt werden.
    Dann wir der Drehzahlmesser in Rot dargestellt.
    L G
    Stone855
  • Hi Stone855,
    ich kopiere es nochmal aus meinem Thread von 18.05.18 hier rein :D :
    Here's the following displays you can change the TFT to:
    00
    : This is the base 500 display. It has the crappy font from the base
    500/500 sport and also features a Sport Mode. I personally do not like
    the font, gauge faces, drives me nuts, YMMV.
    20 : This is another display that I have yet to try.
    40
    : This is the 500T display type. It features a digital turbo boost
    gauge (commanded boost) on the right side of the cluster in Sport Mode.
    I've been using this display for a little over 24 hours now and it works
    great.
    - If you are running this display type in your Abarth,
    your OEM turbo boost gauge will be "turned off" as the 500T does not
    have this gauge. The cluster *runs* that turbo boost gauge. It won't
    even light up. For those that have after market boost gauges in this
    spot, this may cause your aftermarket gauge to not get power or
    illuminate depending on how you wired it. This cluster uses the same
    font as the Abarth cluster. A+.
    60 : This is the Abarth display
    type. It features a throttle position indicator in Sport Mode which does
    not work, Abarth branded Start Up/Shut Down screens and G-Force, which
    does not work. You can simply turn off G-Force and have it display tire
    pressure or the radio or average Kms to get around that issue. Not a big
    deal, but the throttle position gauge, there is not a fix for it yet.
    (This is why I switched to the 500T display type).
    Das sind die, die bislang in diversen Foren bekannt sind! :rolleyes:
    Was am Byte 65, bei dem Riva Modell anders ist, kann uns erst einer sagen, der dieses Model hat und das entsprechend mit MES auslesen kann oder läßt! :023:
    LaFee
